1998 Ford Ranger no power
INYT
  • 1998 FORD RANGER
  • 6 CYL
  • MANUAL
  • 248,960 MILES
My ranger was running good but went to start there was no power it came back but went right back out I checked the battery fuses and relays
Friday, October 23rd, 2009 AT 2:09 PM
  • 109,885 POSTS
If the battery is good and you checked it, check the ground wire at the engine block. Make sure it is clean and tight. Also, remove the battery terminals and clean and tighten them too. Finally, remove the battery, fully charge it, and take it to a parts store to have it load tested.
Let me know what you find.
Tuesday, October 27th, 2009 AT 9:55 AM
