1998 Ford Ranger no cold air
65,000 MILES • 4 CYL • 2WD • MANUAL
JBOWERSETT
My AC doesn't blow very cold air and has been serviced on several occasions to have it fixed. All of the mechanics say that the refrigerant level is fine. One replaced a valve of some kind. The air that comes out of the vents is barely cool and will only cool the cab if set on max and maximum fan, and it takes a long time. I can hear what I think is the compressor cycling on and off quite a lot. Any suggestions?
Thanks, John
Sep 6, 2010 at 1:24 PM
BILLYMAC
  • 2,204 POSTS
i would check the blend air door under the dash this door separates heat from a/c if not closed all the way or not open all the way not much cool air
Sep 12, 2010 at 2:24 PM
