1998 Ford Ranger knock
115,000 MILES • 6 CYL • 4WD • MANUAL
TIM H.
On the way to work the other day I came to a stop light after getting off the freeway and had a loud nocking sound from under the hood. I pulled over and checked the oil which was a little low. I added 1 1/2qrt. and the noise got softer. After work i drove to a friends house were he said it sounds like a rod knock. Having no other car to get to work I drove it today. going to work it was the same as the other day, but on the way home I have to go up a steep incline were the noise got alot louder. I cant find a leak so dont know what could have caused this out of the blue like it happened. Will it be cheaper to find a new enginge or can i take it to someone to fix it?
Nov 10, 2008 at 2:22 PM
  • 31,937 POSTS
Hi there,
If it has a bearing problem, driving it will do a lot more damage, and the repair bill will go up with a crank re grind, so may be it will be cheaper to look for a second hand unit, or go for the fully reco engine, there is no way to know how much damage has been done to the old engine until it is dismantled & inspected.
Mark (mhpautos)
Nov 10, 2008 at 3:02 PM
