1998 Ford Ranger hard steering
LLOYD MIYASHIRO
Steering problem
1998 Ford Ranger Two Wheel Drive Manual 132,00 miles
Hard to turn steering wheel and it takes many turns to turn front wheels slightly.
Nov 29, 2008 at 3:03 PM
DAVE H
  • 13,383 POSTS
you have a power steering fault somewhere ? is the drive belt still on ?? check power steering fluid level .. check pipes for leaks .. if this is all ok .. the pump may have given up .. and needs replacing ?
Nov 29, 2008 at 10:22 PM
BREWCREW442
  • 9 POSTS
When you say it takes a lot of turns to move the wheels a little it makes me wonder if something has come apart. Here's something to check that is a little more obscure....There is a rubber coupling that connects the steering gearbox to the column. If your steeering wheel turns more times lock-to-lock than it used to that may have torn loose. THe other thing that comes to mind is I had a van that the frame rusted out. The idler amr pulled away from the frame and it would only turn one direction. The steering wheel would turn both ways but the front wheels only turned to the right.
Hope I was some help, eliminating things if nothing else.
Dec 1, 2008 at 5:38 PM
