1998 Ford Ranger engine light
LSMITTY1965
Computer problem
1998 Ford Ranger 4 cyl Two Wheel Drive Automatic
engine truns over but will not start. engine light will not self test. all sensor check out ok with ohms meter so is the computer bad
thank you for answering so fast I have checked all the things that you said
dont have fuel but out side power will give me fuel and I have check cam and crank sensors ohms reading are good. dont have spark
thanks
Jun 20, 2008 at 4:31 PM
  • 75,988 POSTS
Scan the computer for OBD2 code/s and comeback with it-Don't think computer till we tell you-
Try below and see what happens, something has to give
If the engine's condition is in tip top shape-do below to determine if its fuel or spark problem that's if its cranking over and refuses to start
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil,distributor pick-up coil, ignition control module, cam and crank sensors-
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
Jun 20, 2008 at 4:36 PM
