i have a code egr insufficent air flow what do i need to do and if i have to replace the egr what is the wrench size for the egr tube
Mar 1, 2009 at 1:11 AM
MERLIN2021
✓Experienced Mechanic
Yep! Pull the egr off, clean the port under it all the way to the throttle plate, I use a length of steel coathanger...put it all back together, reset the codes, if light comes on again, replace the EGR position sensor, thats the one the two small hoses from the exhaust plug into!
Mar 1, 2009 at 1:31 AM
TED-E-DEE
Also remove the pipe that goes from E.G.R. to the manifold & clean it, there is an orrifice in it that gets plugged w/carbon. Use Brake cleaner or Carb cleaner & compressed air.
Apr 29, 2009 at 11:25 AM
MERLIN2021
Original post was Mar 01, Ted, I think it's fixed!
Apr 30, 2009 at 8:40 AM
