I am working on a 1998 Ford Ranger XLT it has a 4.0L V 6 with 135,590 miles on it. It is a Five speed Manual transmission. I recently replaced the fuel synchronize shaft and the cam shaft sensor. When I removed the old sensor it was completely destroyed in pieces. I also removed the shaft to visually inspect it. It was damaged as well. I went to a junk yard and got a shaft from a 98 ford ranger 4.0 L. I put it in and it ran great. By the way I also replaced the plugs and wires and the EGR DPFE sensor. I noticed that the plugs on the 4,5,6 and six were in bad shape the center electrode was almost gone as if the engine had ran real lean on that side. The other side 1,2,3 were the opposite they were black and appeared as though it had run rich on that side. I changed the air filter the oil and Oil filter. I cleared the codes and test drove the vehicle it ran fine. No light nothing at all. Customer arrives picks up the truck and is gone maybe 5 min. Comes in and says the Check Engine light is on. I check it and get the P1309 Misfire Monitor Disabled. Cleared the code drove it for about 30 mins. NO Light. I kill the ignition start it back up drive it down the road about a mile and here comes the light. I have noticed that right after I clear the code it doesn't set on the 1st start but it will on the 2nd. Confused!!!!!!!!!!!!! Any help would be greatly appreciated.
Mar 17, 2009 at 5:34 PM
