How do I check the engine codes on a 95 Ford Ranger?
DUSTIN.P
  • 1995 FORD RANGER
  • 4 CYL
  • MANUAL
  • 22,500 MILES
How do I check the engine codes on a 95 ford ranger, I have been to the autoparts stores they all said they could do 96 and up. Somebody said that I can bypass the relay and check the flashes.
Thursday, January 21st, 2010 AT 6:22 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Your vehicle may not use the OBD II diagnostic system. Auto part stores will say that they can't retrieve codes on vehicles 1995 or older because the OBD II system was very rare in 1995. It became more popular and standard in 1996 and up vehicles. Since your vehicle does have the OBD II system, the part store CAN retrieve the codes for you. Let them know that your DLC (data link connector) is located below the instrument panel, to the right of the steering wheel and that it is indeed OBD II , not OBD I. Here is a guide to help you get the codes.
https://www.2carpros.com/articles/ford-lincoln-mercury-obd1-1995-and-earlier-diagnostic-trouble-code-definition-and-retrieval
Thursday, January 21st, 2010 AT 7:57 PM
