center console
1998 FORD RANGER
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
RLURON
The center console on my Ranger XLT has become loose over time, probably from pulling on it to climb into the truck. I can't find any bolts that I might tighten down and I'd like to know how to remove or tighten the console.
Jun 25, 2010 at 9:43 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Use the picture below to help..You will have to remove the small arm rest screw covers to access the bolts. There will be 4 arm rest bolts and 2 rear arm rest screws along with 2 screws in the front utility tray. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Cheers
Jun 25, 2010 at 5:49 PM
