1998 Ford Ranger blower
140,000 MILES • 4 CYL • 2WD • MANUAL
JESTERKS
I have replaced the blower motor resistor under the hood and the actual fan switch on the dash. Speed #1 still does not work, 2,3 and 4 are fine. any suggestions?
Thanks
Nov 6, 2010 at 5:44 AM
JDL
  • 16,098 POSTS
Your different speeds are controled on the ground circuit. The red wire with orange tracer from blower resistor is ground for the low speed. With the settings on low speed, check continuity to ground. If you have continuity, suspect the blower motor. If no continuity, check the wiring circuit.
https://images.2carpros.com/forum/automotive_pictures/170934_ranger_blower_control_1.jpg
Mar 30, 2021 at 6:46 AM
