1998 Ford Ranger a franme bushings
LAMBERTTAMMY
Suspension problem
1998 Ford Ranger Two Wheel Drive Manual
we are replacing the a frame bushings with adjustable ones. we received a bolt with a large washer. the question is....do we need to add a smaller washer to one side to make it the same thickest and add a smaller washer to the nut side?
Jan 11, 2010 at 9:40 AM
  • 110,248 POSTS
I'm not sure what type of product you purchased. The frame bushings are a rubber mount with large washers. You shouldn't need to add anything. Did the kit you got come with any type of directions?
Jan 12, 2010 at 12:16 AM
