1998 Ford Ranger 4WD High and 4WD Low lights flashing
1998 FORD RANGER
122,000 MILES • 6 CYL • 4WD • MANUAL
AICFANATIC74
Have a '98 Ranger 4WD, 4.0L V6, with 122,000 miles, manual transmission. The 4WD High and 4WD Low lights flash 6 times, then seem to go 2 minutes, and flash 6 times again, until I shut off the engine. Let it cool, drive it another day, and it may not happen. Seems to be intermittent. No noticable sounds or smells, or performance change. 4WD High still functions as it should, and shifts back to 2WD normally. 4WD Low has never been used.
Feb 12, 2010 at 10:19 AM
KHLOW2008
  • 41,814 POSTS
Hi aicfanatic74,
Thank you for the donation.
When the indicator light blinks, an error has been detected in the system and you would need appropriate scanners to diagnose the problem.
It could be a loose or contaminated wire connector or a lazy solenoid.
Feb 12, 2010 at 9:52 PM
