1998 Ford Ranger 4 Wheel Drive
CHIEF030
  • 1998 FORD RANGER
Drive Train Axles Bearings problem
1998 Ford Ranger 6 cyl Four Wheel Drive Automatic
The 4 wheel drive will not go in.T works in High range but will not go in low range
Wednesday, January 6th, 2010 AT 2:00 PM
  • 109,885 POSTS
If the transfer case will shift into 4wd high, then the unit and front axle are working. If it doesn't go into low loc, then either the actuator on the transfer case or the switch / wiring is bad. Unplug the wiring harness to the actuator and make sure it is clean and not corroded. Also, have a helper switch to 4 lo whille you check for power to the harness. If you are getting power, then the actuator is the problem.
Tuesday, January 12th, 2010 AT 10:43 AM
