1998 ford ranger 4.0 115,
JEFTFIELDS
  • 74 POSTS
i have a miss in #4 cyl,have put in newplugs,wires.
comppestion in cyl, is 110.sets a code in comp, #4 missfire det,.no other codes.it seemes to be intermettent,because it is not all the time.replaced maf sensor,seems to help it when you unplug maf.
Jan 24, 2007 at 12:38 PM
SERVICE WRITER
  • 9,123 POSTS
Seems like the dealer MAF is the way to go with these. The test you did helps support that. Maybe return it for an exchange if it's aftermarket?
Jan 24, 2007 at 12:45 PM
JEFTFIELDS
  • 74 POSTS
the oem maf did the same thing,as the repacment.we have also found 2 broken spark plug inselaters,#4,#6.this has been going on for,on and off,6 months.not sure if it is a loose wire or bad computer,or what.i have pulled all my hair out trying to find the problem.WE ALSO HAVE TEMP. BROBLEMS NOT HEATING UP,REPLACED THERM.DID BETTER NOT FOR LONG.HAD 1 MECH,TELL ME THAT THE TEMP MIGHT BE THE PROBLEM IN THE MISSFIRE.
Jan 24, 2007 at 12:48 PM
JEFTFIELDS
  • 74 POSTS
I HOPE SERVICE WRITER SEES THIS ONE AGAIN
Jan 28, 2007 at 11:09 AM
SERVICE WRITER
  • 9,123 POSTS
Hey Jet!
I have a 98 but with a 3.0.
Can you check the coeds? err...codes.
But hey if you have coeds, check them too! :lol:
Has there been any other heating issues?
do you have heat in the cab?
It's probably a little chilly being bald, eh?
Jan 28, 2007 at 11:15 AM
JEFTFIELDS
  • 74 POSTS
THE ONLY CODE IT SHOWS IS MISFIRE DETECTED IN #4 CYL,THE HEAT DOES HEAT IN CAB BUT TAKES SOOM TIME TO DO ANY GOOD. IM GOING TO REPLACE THEM, AGAIN JUST TO MAKE SURE .
Jan 28, 2007 at 11:19 AM
SERVICE WRITER
  • 9,123 POSTS
Them?
Thermostat sounds questionable, have seen many be bad from the get go. How old are the wires? You can try swapping 2 wires to see if the misfire moves. Can do the same with injectors.
Pull the # 4 plug and see if it is wet or any other tell tale signs.
Get a spark tester and put it on that cylinder to make sure it's getting spark
Jan 28, 2007 at 11:40 AM
JEFTFIELDS
  • 74 POSTS
no matter what we have done from changing wires,plugs,the missfire does not move,remains in #4.wires,plugs,less than 5,000 miles.my boss suggjested the inj.flush havent done that yet,just making we have toched all the bases first.
Jan 28, 2007 at 12:22 PM
SERVICE WRITER
  • 9,123 POSTS
Well, let's go back to basics.
What do you definitly know?
Is it getting spark to that cylinder?----how do you know?
Jan 28, 2007 at 9:21 PM
SERVICE WRITER
  • 9,123 POSTS
Is it getting fuel to that cylinder?----how do you know?
Jan 28, 2007 at 9:22 PM
SERVICE WRITER
  • 9,123 POSTS
Is it getting compression on the cylinder?----how do you know?
JEFTFIELDS
  • 74 POSTS
the only thing im not sure of is the fuel in that cyl,checked spark with a spark tester,and plug.checked comp,with a tester its at 90-110 psi,the only thing im not sure how to test is the fuel in that cyl,with out taking plenam apart and testing inj, that way.but that may be what i do next.
Jan 29, 2007 at 11:04 AM
SERVICE WRITER
  • 9,123 POSTS
If I'm, going into there and spend 2 hours to do it, I'd be inclined put in a new injector.
Jan 29, 2007 at 11:28 AM
JEFTFIELDS
  • 74 POSTS
that what i was thinking also well thanks for all your input on the subject i wont bother you again. thank you paul
jeff.
Jan 29, 2007 at 11:31 AM
SERVICE WRITER
  • 9,123 POSTS
Not a bother, this is fun for me. I wish I could be more of a help, but my technical skills are limited.
Jan 29, 2007 at 11:36 AM
