1997 Ford Ranger Vacuum system
19,500 MILES • 4 CYL • 2WD • MANUAL
JCROWN
Hi
What is the best way to find a vacuum leak on the engine. I have a P0171 fault code (system too lean). A friend said that can either be caused by a vacuum leak or a bad mass air flow sensor. I'd like to check for the vaumm leak first.
Dec 28, 2007 at 4:20 AM
FAIRRACING31
  • 150 POSTS
Get a can of gumout and spray it around your vacuum hose's and intake manifold. When you hear your RPM change, you have found your leak.
Happy New Year :)
Dec 31, 2007 at 9:43 AM
