Changed the clutch and slave cylinder/throwout bearing on the truck.The shifter is stuck in neutral,and wont go to any other gear,even when the truck is running,and clutch pedal is pushed in.I bled the slave cylinder.Did I mess up on something?
Mar 12, 2010 at 12:58 AM
