Engine Mechanical problem
1997 Ford Ranger 6 cyl Four Wheel Drive Manual
Do you have to drain the coolant to change the thermostat?
Thursday, November 20th, 2008 AT 5:50 PM
DAVE H
MECHANIC
You do not have to drain the whole system to change thermostat. Take off the pipes going to thermostat housing obviously you will lose coolant. Take off housing . Replace thermostat. Replace housing. Refill system. And bleed system. Let the engine get hot enough for thermostat to open.
