1997 Ford Ranger changing a thermostst
140,000 MILES • 4 CYL • 2WD • AUTOMATIC
NOBEAN
what do i need to do to get to the housing to have the access to change thermostat
Oct 4, 2009 at 3:46 AM
  • 110,246 POSTS
I'm not sure I understand your question. If you follow the upper radiator hose from the radiator to the engine, it will lead you to the t-stat housing. THere are 2 bolts that hold it on. Just remove them and the housing will come off exposing the t-stat.
Oct 28, 2020 at 5:30 AM
