Purge valve C fault code P0443
99,000 MILES • 6 CYL • 4WD • MANUAL
RANGER097
I have the code p0443 on my truck. I have had this for a while now. I replaced the purge valve, reset the PCM (thanks to AutoZone), let it sit and idle for a a couple hours, shut it off, started it again and the light came right back on. I also had EGR valve insufficient flow code and i replaced the EGR pressure sensor and that code went away no problem. I am wondering what else I should do to get this code (P0443) to go away. I am very clueless. Thanks.
Jul 23, 2010 at 2:01 PM
MERLIN2021
  • 17,250 POSTS
This is a common problem the EGR passages get clogged and need to be cleaned out. Remove the EGR and use carburetor cleaner and a coat hanger to remove the build up.
Please report back.
Cheers
Jul 24, 2010 at 3:02 AM
OLDGURU
Yep, I had this problem as well the ports were filthy, all fixed.
Jul 7, 2018 at 3:55 AM
