1997 Ford Ranger Problems getting Transmission into gear
PMG1
Transmission problem
1997 Ford Ranger 4 cyl Two Wheel Drive Manual
How can you tell if your clutch is the problem or the master clutch cylinder is the problem when you have problems getting you truck in gear or changing gears - not every time but becoming more frequent.
Oct 12, 2009 at 3:57 AM
  • 110,248 POSTS
Usually a clutch / pressure plate will get worse as it gets hot. The slave cylender will do it all the time. Make sure the fluid is full in the reservoir is full.
Oct 28, 2009 at 1:14 AM
