The dome/glove box light and windshield wipers won't work(or do intermittently) and the problem happens only when it is raining. The "bright" engineers at Ford put the 4WD circuit on the same circuit as the dome/glove box circuit so they also won't work. I think the wipers are on a different circuit so this really adds to my frustration. I have changed/swapped out the fuses
in the cab and engine compartments and even the wiper, wiper hi-lo relays in the engine compartment. I also changed the wiper motor. All to no avail. I suspect possibly an ignition switch problem or an in-dash relay problem because when the dome light and wipers finally kick in, I here an in-dash relay "click"
Please help....I am completely baffled by this problem
as the problem happens only when it is raining outside!!
Mar 9, 2008 at 11:56 AM
