Tuesday, January 15th, 2008 AT 9:26 PM
I have all the heat I can use. So far I have replaced the vacuum valve that shuts off water flow to the core and the reostat in the dash that adjusts heat. It does not matter where I have the heater adjustment I get full bore heat. The only way to turn off the heat is to turn off the heater.
