1997 Ford Ranger Heater control does not adjust heat.
11,300 MILES • 6 CYL • 4WD • AUTOMATIC
ROBERT PARKS
Dial control which should regulate cold to hot does not. I do have cold if I swithch to max air, all other blows as if turned to full heat. Where do I begin?
Jan 9, 2008 at 9:07 AM
BLACKOP555
  • 10,386 POSTS
check your blend door in the vents and your heater control valve.
Jan 9, 2008 at 9:36 AM
DBONAMY
Hey Robert your blend door might have broken loose my 97 ford ranger did the same thing and my blend door broke the tap on top of the blend broke i had to remove the dash to take out the the hearter unit to repair the blend door
Dec 7, 2010 at 6:58 PM
