1997 Ford Ranger Heat/AC
13,000 MILES • 4 CYL • 2WD • MANUAL
DRAGONSTAR
My heat/A/C has been working intermittently lately. Temp gauge also has been dropping on the low side (cool). Is this just a thermostat or something more? Perhaps a coolant charge needed for A/C? Kinda need heat now as it is mid-Nov in northern VA and just had our first snow. Smile! Otherwise, truck runs fine.
Nov 17, 2008 at 11:45 AM
THETESS
I have a similar problem but my thermostat reading is running high and I'm not getting AC. Anyone have an answer to either of our problems?
Nov 26, 2008 at 12:33 PM
DRAGONSTAR
[quote:806707efa5="TheTess"]I have a similar problem but my thermostat reading is running high and I'm not getting AC. Anyone have an answer to either of our problems?[/quote:806707efa5]
Hi
I'm not a mechanic but suggest you check the coolant level. Also check your overflow bottle (if empty, fill to the fill line with coolant/water as recommended). Also check under your truck in the morning to see if you are leaking fluid. Also check your oil level. Worst case is you need a charge on your A/C. Your situation sounds easier to solve than mine in my opinion. I wish you luck!
Nov 26, 2008 at 1:39 PM
