1997 Ford Ranger Fuel Filler Hose
1997 FORD RANGER
99,000 MILES • 4 CYL • 2WD • AUTOMATIC
STRAND2001
I am looking to buy the rubber hose that leads from the gas cap to the fuel tank with the metal vent tube inside and I do not know the exact part name could you help?
Dec 30, 2007 at 4:54 AM
MERLIN2021
  • 17,250 POSTS
Thermostat is a good start! May be the waterpump, I have seen the vanes actually corode...see if you can tell if the coolant is circulating....look in the recovery bottle for swirling action.
Nov 23, 2007 at 11:36 AM
CANDTALWAYS
  • 10 POSTS
93 f150 351,I just had the waterpump replaced about 4 months ago.Could it go bad in such a short period of time,also I though if the waterpump was bad there would be a small leakage from the weep hole on the pump?Also i flushed the radiator system out a couple months after having it put on and it was alot of rust.Should I still look into having the waterpump changed and is there anyway to test it to see if its bad?
thanks for the reply.....
Nov 23, 2007 at 1:28 PM
CANDTALWAYS
  • 10 POSTS
i've looked in the recovery unit and i didn't see any kind of swirling motion.is this a good thing or is it suppose to have some sort of swirling motion?also i changed my thermostat and it still runs hot.i was wondering if perhaps it could be a faulty temp sensor?
Nov 24, 2007 at 11:09 AM
98RANGERXLT
  • 301 POSTS
Do what justan old told you then get back to us
Nov 26, 2007 at 11:30 AM
BLACKOP555
  • 10,386 POSTS
the name is the fuel filler hose.
Dec 30, 2007 at 5:32 AM
