1997 Ford Ranger Fan Speed Control
56,000 MILES • 6 CYL • 2WD • AUTOMATIC
RDTECBIKER
My fan speed control only works on High Speed. I assume it is the fan control switch.
Oct 25, 2009 at 1:16 AM
  • 110,248 POSTS
Chances are the switch is fine. Most likely, the blower motor resister needs replaced. It's a cheap part.
Mar 30, 2021 at 6:46 AM
RDTECBIKER
Replacing the Blower Motor Resistor fixed my problem. Thank You.
  • 110,248 POSTS
You're welcome. I'm glad you got it taken care of. Let us know if you have questions in the future, and thanks for using 2carpros.com.
