HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Ranger
Climate Control
Blower Fan
Resistor
1997 Ford Ranger Fan Speed Control
RDTECBIKER
MEMBER
1997 FORD RANGER
6 CYL
2WD
AUTOMATIC
56,000 MILES
My fan speed control only works on High Speed. I assume it is the fan control switch.
Sunday, October 25th, 2009 AT 8:16 AM
MECHANIC
Chances are the switch is fine. Most likely, the blower motor resister needs replaced. It's a cheap part.
Tuesday, March 30th, 2021 AT 1:46 PM
RDTECBIKER
MEMBER
Replacing the Blower Motor Resistor fixed my problem. Thank You.
MECHANIC
You're welcome. I'm glad you got it taken care of. Let us know if you have questions in the future, and thanks for using 2carpros. Com.
Please
login
or
register
to post a reply.
Related Blower Fan Resistor Content
Blower Motor Resistor Problem
Replaced Blower Motor Resistor Because Only Ran On Hi. Worked On All Speeds About 3 Days, Now Same Thing Only Runs On Hi. Any Idea Where I...
Asked by
superrat
2001
FORD RANGER
Replace Heater Blower Motor Resistor
How To Replace Heater Blower Motor Resistor?
Asked by
alphonsus
2 IMAGES
2007
FORD RANGER
1990 Ford Ranger Low Air Flow
I Have Replaced Blower Motor, And The Blower Motor Resistor And Plug, And With Ac Or Heat There Is Hardly Any Air Flow
Asked by
cturner1001
1 IMAGE
1990
FORD RANGER
1998 Ford Ranger Blower Motor
The Blower Motor On The '98 Ranger Only Works On High. On Chryslers, It's A Resistor Located Under The Glovebox: I Suspect It's The Same...
Asked by
zaleskd
1 ANSWER
1998
FORD RANGER
I Have Replaced The Blower Motor Resistor Under The Hood And The Actual Fan Switch On The Dash. Speed #1 Still Does Not Work, 2, 3 And 4...
Asked by
jesterks
1 ANSWER
1998
FORD RANGER
VIEW MORE
How to Use a Test Light
How to Replace the A/C Blower Motor
Heater Not Working
