1997 Ford Ranger electrical
223,000 MILES • 6 CYL • 2WD • MANUAL
LFFG
high beam and brake light in dash stay on after ignition is turned off, and key removed. This killed the battery.
Dec 29, 2007 at 8:22 AM
BMRFIXIT
  • 19,053 POSTS
[quote:4f368e3efb="LFFG"]1997 Ford Ranger 6 cyl Two Wheel Drive Manual 223000 miles
high beam and brake light in dash stay on after ignition is turned off, and key removed. This killed the battery.[/quote:4f368e3efb]
check the alternator wires also if you have or had an alarm or remote starter check wiring
Dec 29, 2007 at 3:30 PM
