1997 Ford Ranger continuation info to failed smog at idle
1997 FORD RANGER
141,000 MILES • 4 CYL • 2WD • MANUAL
BRIANMRICHEY
1st test (12-02-09) 720 rpm, HC = 28. 2nd test (12-04-09) 730 rpm, HC =146. 3rd test (12-21-09) 722 rpm, HC = 126. How could this be?
Dec 22, 2009 at 8:41 AM
Hi brianmrichey, Welcome to 2carpros and TY for the donation and selecting us as your auto repair site Feel free to ask questions at anytime and Merry Christmas and a Happy New Year 2010
Hydrocarbon failures mean unburned gasoline is passing through the engine and entering the exhaust. The three most common causes include ignition misfire, lean misfire and low compression (typically a burned exhaust valve). Ignition misfire can be caused by worn or fouled spark plugs, bad plug wires or a weak coil. Lean misfire results where there is too much air and not enough fuel, so check for vacuum leaks, dirty injectors or a fuel delivery problem. In addition to these, hydrocarbon failures can also be caused by oil burning due to worn valve guides, valve guide seals and/or rings.
Dec 22, 2009 at 8:46 AM
