1992 Ford Ranger wont pass smog
200,000 MILES • 6 CYL • 4WD • AUTOMATIC
SHOGOX10
my ford wont pass smog i pulled up the codes off it
an it cam up with a 171 an i looked it up an it says something a bout a map sensor but i cant find it
Mar 24, 2009 at 9:19 AM
  • 75,988 POSTS
Which engine do you have 2.9/3.0/4.0L???
Mar 24, 2009 at 9:28 AM
SHOGOX10
the 4.0 its also coming up with high CO
Mar 24, 2009 at 9:30 AM
SHOGOX10
[quote:638225c405="rasmataz"]Which engine do you have 2.9/3.0/4.0L???[/quote:638225c405]
Mar 24, 2009 at 9:49 AM
  • 75,988 POSTS
High carbon monoxide (CO) emissions are a telltale sign of a rich fuel mixture. On older carbureted vehicles, fuel-saturated plastic floats, incorrect float settings, leaky power valves and misadjusted chokes are often responsible for the rich mixture. On newer vehicles with feedback fuel controls and fuel injection, leaky injectors, excessive fuel pressure and sluggish or contaminated O2 sensors are all possibilities to investigate.
Mar 24, 2009 at 10:05 AM
SHOGOX10
then waht about the map sensor. dose it even have one
Mar 24, 2009 at 10:11 AM
  • 75,988 POSTS
The MAF sensor is on the air cleaner assembly
Mar 24, 2009 at 1:02 PM
