1997 Ford Ranger Computer is beeping
1997 FORD RANGER
ABURNS1158
Electrical problem
1997 Ford Ranger 4 cyl Two Wheel Drive Manual
replaced solenoid, new solenoid did not work ,when I jumped solenoid with screwdriver motor started but starter stayed engaged. some smoke from stater before I was able to shut it down.. now even if i jump batt. to started directly ...nothing but a beeping seems to be coming from computer. I may have mix a couple off wires when conecting solenoid.. please help just put bakes tires and timing belt in this truck plus many hrs.
Thanks
Andy
May 21, 2008 at 11:00 AM
MASTERTECHTIM
  • 4,750 POSTS
if you are jumping right to the starter and nothing is happening then replace the starter motor, its fried.
May 22, 2008 at 11:24 PM
