Hi robitron,
When you start the engine in gear with clutch depressed, do you feel any power transmitted to the wheels as if the clutch is not fully depressed?
I suspect your problem is due to the clutch disc sticking/stuck. The dampers could have detached themselves to get lodged in between the pressure plate and flywheel.
Sep 30, 2008 at 2:47 PM
