HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Ranger
Engine
Camshaft
Actuator
Replace/Remove
SPONSORED LINKS
1997 Ford Ranger camshaft synchronizer
MGIRAUDY77
MEMBER
1997 FORD RANGER
6 CYL
2WD
AUTOMATIC
14,800 MILES
How do I change a camshaft synchronizer
Thursday, June 4th, 2009 AT 11:09 PM
BILLYMAC
MECHANIC
Hi do you mean cam sensor. If so it has a plug and one bolt and bolts in the front of the timeing case
SPONSORED LINKS
Saturday, June 6th, 2009 AT 8:36 AM
MGIRAUDY77
MEMBER
I am talking about the part the cam sensor sits on
Wednesday, June 10th, 2009 AT 8:53 PM
Please
login
or
register
to post a reply.
Related Camshaft Actuator Replace/Remove Content
Ranger Ignition Actuator Repair
I Have A 96' Ranger And The Actuator Rod Going From The Ignition To The Switch Appears To Be Broken. Have Removed The Steering Wheel And Air...
Asked by
xxxtina63
6 IMAGES
FORD RANGER
After Replacing The Camshaft The Engine Is Smoking
Hi, My Truck Is Smoking After Replacing Cam Shaft.
Asked by
oagile
28 IMAGES
2000
FORD RANGER
Camshaft Timing Marks
Cannot Find Any References To Timing Marks.
Asked by
Mikell Ramirez
10 IMAGES
2006
FORD RANGER
Timing Marks For A 2.3 Engine
What Do The Timing Marks Look Like For My Truck Listed Above It Has The 2.3 Liter Engine. The Timing Belt Has Been Removed And The Crank...
Asked by
revkev316
8 IMAGES
1993
FORD RANGER
Timing Belt Marks Diagram
Timing Belt Diagram Ford 2.5 Please.
Asked by
hairball55
1 IMAGE
1999
FORD RANGER
VIEW MORE
SPONSORED LINKS
Camshaft Position Sensor Replacement
Engine Noises
Misfire Random Code P0300
Online car repair manuals
