1997 Ford Ranger 1997 Ranger radiator question
16,000 MILES • 4 CYL • 2WD • MANUAL
LEEONDRAW
My 1997 Ranger engine is running hot. Not in the red, but right up there near the top of the white section. This winter I kept smelling anti freeze and knew the heater core was breaking down so I took it in and had the core capped off (The co. wanted $700.00 to fix/replace the core because it is in a weird place that requires removing the dash!! Couldn't do it). Ever since, it has been running hot and the smell continues. I have already had the thermometer and fan clutch changed. Unless I have been duped, both of these items are new. Running the fan seems to affect things, but I don't have AC. Do you think I need to replace the radiator next? If so, how much should this cost? I live in Memphis, TN
Thank you so much for your time and reply.
Jun 6, 2010 at 7:30 PM
  • 31,937 POSTS
Hi there,
go get the radiator core cleaned at a radiator shop, it may have a partial blockage, start here.
mark (mhpautos)
Jun 6, 2010 at 11:31 PM
