1997 Ford Ranger 12 Volt Outlets
12,400 MILES • 4 CYL • 2WD • MANUAL
DAVEDAD75
I have three 12 volt charging outlets-2 up on the middle part of the dash and the cig. lighter right above the cupholders. None of them work. I checked the fuse-good. I took the dash apart to check the wiring-appears good. I get 12 volts to the top left outlet, but the charging socket has no power-will be replaced today. Would that cause the other two not to work or am I missing something in the circuit?
Oct 24, 2008 at 5:15 AM
BMRFIXIT
  • 19,053 POSTS
checked for power
know check for ground
if no ground still will not work !!
Oct 24, 2008 at 3:31 PM
