1997 Ford Ranger
POISON_1982
Other Category problem
1997 Ford Ranger 4 cyl Two Wheel Drive 110000 miles
I have a vibration in my front right and it pulls to that side while dirving at any speed
Dec 26, 2007 at 1:41 AM
BLACKOP555
  • 10,386 POSTS
check your wheel bearing on that wheel, jack up the front end and if the wheel turns freely its not that if its rough or sticky then you should change it. also if it wiggles laterly or verticle it should be replaced.
check the tire for wear on the inside excessivly
Dec 28, 2007 at 2:02 AM
