1997 Ford Ranger
190,000 MILES • 4 CYL • 2WD • MANUAL
XXYOUNG724XX
I have a 1997 ford ranger 2.3l 4 cylinder that keeps setting check engine light with a p1137 dtc. What could cause it to throw this code?
Aug 27, 2010 at 1:55 PM
BLUELIGHTNIN6
  • 16,542 POSTS
most likely cause is a faulty oxygen sensor but also check the engine oil to ensure it is clean , check the spark plugs ensure they are sparking healthy, check for leaks in the air intake system and also check for dirty fuel filter.
Aug 27, 2010 at 2:59 PM
