1997 Ford Ranger
SLOUDEN
1997 Ford Ranger 6 cyl Four Wheel Drive Automatic
i have a 1997 ford ranger xlt 4.0 i was in iraq so it sit for almost 2 years now that im running it again it smokes black out of the exhaust it clears up some up some after it runs a little while it also has a miss to it as well before i left for iraq a put a new oxygen sensor in it it was burning to rich and i lost alot of fuel milage and it was smokeing after i changed it and changed plugs and wires it was ok but after it sit it has this problem. any ideas?
Mar 20, 2009 at 6:02 PM
BMRFIXIT
  • 19,053 POSTS
Thank you
and welcome home
it sat for two years
I would still recheck the tune up and make sure its firing on all cylinders
check for codes
as I believe you have a check engine light on as engine running
most local part store will help in scanning it for you for free and they will give u a code s
let me know what you have
check MAF sensor
Mar 20, 2009 at 11:21 PM
