1997 Ford Ranger
145,000 MILES • 4 CYL • 2WD • MANUAL
MCKEY14
hi i have a 97 ranger and i just replaced the battery so i know its not that. but when i turn the key nothin happens no sound nothing. so i dnt no whats goin on and i dnt no if i should be able to do this but i can take the keys out while its running. i just need to no what i need to do a/s/a/p because i have to push start it every time i shut it off
Nov 26, 2008 at 3:36 AM
RENAUDTN
  • 636 POSTS
Check for voltage at the starter while someone attempts to crank the car; if you get voltage at the starter but starter doesn't engage, replace starter. if you get below 10V at the starter, it's not enough to engage it, and at this point you would need to do a voltage drop test on the ignition circuit to find which component is defective.
If you don't have voltage at the starter, check your solenoid, clutch pedal safety switch, and ignition switch.
By the way you shouldn't be able to remove the key from the ignition when the car is running.
Nov 26, 2008 at 7:59 AM
