My 1997 Ford Ranger (4.0L,V6) stalls when coming to a stop or when idling. It is more common in cold weather. Check Engine codes are PO171 and PO174. I have replaced the Mass Air Flow Sensor and the Idle Air Control valve. The PCV valve and hose seem to be fine, as well as other vacuum lines. Any other ideas?
Nov 22, 2008 at 9:43 AM
