1997 Ford Ranger
160,000 MILES • 6 CYL • 2WD • MANUAL
JBKAVA2
i have 97 ford ranger with check engine. it has a p0174 code. (lean bank 2) what can be causing this?
Jul 31, 2008 at 9:00 AM
MERLIN2021
  • 17,250 POSTS
You may have a vacuum leak, get a can of spray gumout, spray the vac lines and maniflod area, when the idle changes, youve found the leak! You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs! If no leaks found, check fuel pressure.
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
Jul 31, 2008 at 9:04 AM
