What is the problem when there is a lot of water in the exhaust but not in the oil? I just changed the radiator and had to drive with a water leak in the old radiator and let it overheat, once otherwise the water was at higher than normal temps, so after changing the radiator, I get white smoke from exhaust, and water out the tail pipe. What would be the solution without spending a whole lot of money as I am broke?
PS: I cannot afford any money at present except maybe a dollar if you can help. [img:43592415f9]http://www.2carpros.com/forum/automotive_pictures/429085_crystal003_1.jpg[/img:43592415f9]
Oct 31, 2009 at 9:23 AM
