1996 Ford Ranger Water in exhaust, but not oil
175,000 MILES • 4 CYL • 2WD • MANUAL
CRYSTALEAGLEUS
What is the problem when there is a lot of water in the exhaust but not in the oil? I just changed the radiator and had to drive with a water leak in the old radiator and let it overheat, once otherwise the water was at higher than normal temps, so after changing the radiator, I get white smoke from exhaust, and water out the tail pipe. What would be the solution without spending a whole lot of money as I am broke?
PS: I cannot afford any money at present except maybe a dollar if you can help. [img:43592415f9]http://www.2carpros.com/forum/automotive_pictures/429085_crystal003_1.jpg[/img:43592415f9]
Oct 31, 2009 at 9:23 AM
MATHIASO
  • 1,209 POSTS
Some water droplets and some white steam coming from the tailpipe on first start up…usually worse on humid days, is normal. Once the engine heats up to normal operating temperature (about 210 degrees F) the water should dry up and go away.
If there is water or steam from the tailpipe after you have been driving around awhile and the engine is at operating temperature….then you might have a problem, but from what you told me I don’t think you have a problem.
Oct 31, 2009 at 9:50 AM
