vacuum control purge valve
1996 FORD RANGER
154,794 MILES • 6 CYL • 2WD • AUTOMATIC
D_C
I am trying to get it to pass smog. i have a OBD II computer and the code P1143 comes up, this is the Evaporative Emission Control System. we have changed the solenoid, which was not working before, and it is now fixed. but the code still reads the same. how can i get this problem solved so it can pass smog?
Dec 30, 2007 at 9:10 AM
MERLIN2021
  • 17,250 POSTS
Can you recheck that code? No such code for Ford...they run to 1142 then skip to 1150....
Dec 30, 2007 at 10:00 AM
D_C
sorry, my mistake. its code P1443
Dec 30, 2007 at 10:35 AM
MERLIN2021
  • 17,250 POSTS
Ok it is the evap system, the way leaks are found in this system is with a smoke test, they hook up you system to a low pressure machine that pumps smoke in, where the smoke comes out, is were the leak is! Look for obvious cracks in the EVAP lines to begin with
Heres a guide on using a meter
See attached trouble tree to get things started
Dec 31, 2007 at 8:55 AM
JHASK3824
  • 8 POSTS
would like to know location of evap emissions control systems control valve ????
engin code po171,174 & p1443
Mar 14, 2019 at 10:58 AM (Merged)
DOCFIXIT
  • 18,828 POSTS
see diagram of EVAP also 171 and 174 are lean bank 1 and 2
Lean fuel condition could be caused by one of the following below:
1.Vacuum leaks
2.EGR and PCV valve.
3.Low fuel pressure.
4.Dirty fuel injectors.
5.Mass Air Flow Sensor.
6.Oxygen Sensor.
