In the winter, I can start my ranger, but if I cut the engine after a few minutes and try to start it again, the engine will not turn over. I usually have to let it sit for at least a half hour before I can get it to turn over again. I think there's an issue with a fuel sensor or fuel pressure regulator. If this is the case, is it a cheap fix? Do you suspect this to be the problem?
Jan 6, 2009 at 3:10 AM
