1996 Ford Ranger speed sensor
DUNNAGE
Electrical problem
1996 Ford Ranger Four Wheel Drive Automatic
my 1996 ford rangers Speedometer will not word. I replaced the sensor on the rear axle. and still did not work. Is there also one on the transmission. it is electronic but not digital. if not what should i try next? I also took out the instrument cluster to replace the check engine light. it stays on all the time and the code said it was the speed sensor. Thanks for any help you can give me
Aug 2, 2010 at 10:39 AM
SATURNTECH9
  • 30,868 POSTS
What is the code number so i can get you the trouble tree for you.Also what size engine do you have?
Aug 2, 2010 at 10:50 AM
DUNNAGE
it is a 4.0 the code was p0500
Aug 2, 2010 at 10:53 AM
SATURNTECH9
  • 30,868 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_1996_ford_ranger_P0500_part1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1996_ford_ranger_P0500_part2_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1996_ford_ranger_P0500_part3_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1996_ford_ranger_P0500_part4_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1996_ford_ranger_P0500_part5_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1996_ford_ranger_P0500_part6_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1996_ford_ranger_P0500_part7_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1996_ford_ranger_P0500_part8_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1996_ford_ranger_P0500_part9_1.jpg
There is the trouble tree the speed sensor is located on the left rear of the transfer case since you have a 4 wheel drive.
Aug 2, 2010 at 11:41 AM
DUNNAGE
Thank you
Aug 2, 2010 at 12:41 PM
