1996 Ford Ranger shifting problems
179,542 MILES • 6 CYL • 4WD • MANUAL
MALASTIK666
my vehicle has no problem shifting when engine is turned off, but while engine is running i have extreme difficulty shifting, sometimes are worse than others and i can't shift at all. most of the time when i try to shift into reverse, while stationary, it grinds, but not always, when i cant shift into first i grind it into reverse and then i am able to shift into first with little difficulty but still not smooth
Feb 12, 2009 at 12:34 PM
RANGERDANGER17
  • 224 POSTS
clutch pedal free play needs to be adjusted
Feb 13, 2009 at 4:46 AM
