HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Ranger
Engine
Symptoms
Revs Up
1996 Ford Ranger engine will not excellirate
HARRYPAPPAS
MEMBER
1996 FORD RANGER
4 CYL
2WD
MANUAL
150,000 MILES
My engine start run miss alittle but when I step on gas pedal no incease in rpm and it dies what are some of the possible problems
Monday, July 14th, 2008 AT 6:58 AM
OBXAUTOMEDIC
MECHANIC
Is you engine light on? If so pull codes and post.
Souds like the Throttle Position Sensor.
Monday, July 14th, 2008 AT 7:23 AM
Please
login
or
register
to post a reply.
Related Engine Revs Up Content
1998 Ford Ranger Truck Revving Up By Itself
I Changed Tps Sensor Ok For A While Then It Started Revving Up Again I'lll Give Up And Need Your Help Now This Morning It Started To Run...
Asked by
bmendez46
1998
FORD RANGER
GUIDE
Idle Air Control Motor Replacement
The idle air control motor or idle speed control motor is designed to adjust the air flow into the intake manifold at engine idle. Engine idle speed is monitored by the PCM...
1998 Ford Ranger Rpm
Hello.I Have A 98 Ford Ranger With 3.0 V6 Engine, Manual Transmission. My Problem Is That When The Truck Is Rolling The Rpm's Stick At 2000...
Asked by
IRON LUNG
1998
FORD RANGER
1999 Ford Ranger Engine Revs
My Engine Revs Out 50% Of The Time When I Shift Or Push In The Clutch To Stop. I Cant Find A Vacuum Leak. Just Replaced The Maf Sensor And...
Asked by
kbones
1999
FORD RANGER
2002 Ford Ranger Engine Rpm
After Engine Is Warm, With Defroster On, Rpm Drops About Every 3-4 Seconds, And Sometimes Stalls.
Asked by
dragonpuff
2002
FORD RANGER
2002 Ford Ranger Normal Rpm At 55 Mph
My Ford Ranger (2.3l 4cyl 2wd 5 Speed Manual Trans) When I Run It Down The Highway At 55mph The Rpms Range From 2300-2400. This Seems High...
Asked by
ACfan
1 ANSWER
2002
FORD RANGER
VIEW MORE
Vacuum Leak Symptoms
Vacuum Leak
