1996 Ford Ranger driver window regulator replacement
1996 FORD RANGER
127,186 MILES • 6 CYL • 2WD • AUTOMATIC
MSTRASSE1
Replacing the regulator requires that I drill out 3 rivets. Will I be able to replace these rivets with 1/4 inch bolts when installing the new regulator?
May 25, 2010 at 10:42 PM
  • 31,937 POSTS
Yes you can, just make sure that nothing fouls the regulator or the glass through the full movement up and down.
mark (mhpautos)
May 26, 2010 at 12:04 AM
