1996 Ford Ranger Clutch?
240,000 MILES • 6 CYL • 4WD • MANUAL
KEVIN WATERBURY
Was driving home from a long trip. Down shifted to 4th on the highway and then tried to go back into overdrive. No way. Would not go back into any gear. Pulled over and it slipped into gear. Brought back up to speed and hit a traffic jam. Pushed clutch in to stop. It was still in 1st but the clutch was in and it kept going and stalled. Took off ramp and came to stop. It went into gear. I went back to the free way and it shifted into all gears. Drove another 150 miles home. Now it will not go into gear unless you force it. It is parked. I was ready to tear down the clutch but thought I should ask you guys.
Thanks
Jun 16, 2010 at 9:17 AM
  • 110,248 POSTS
If you are able to shift the gears normally when the engine is off, the trans is good. You have one of two problems. Either the slave cylender is bad, or the pressure plate is. If this happened all at once, my first guess would be the slave. A pressure plate usually goes bad over time. CHeck to make sure the fluid is full in the resivour, and check to see if there is anything leaking between the trans and engine.
Let me know what you find of if you have other questions.
Jun 16, 2010 at 1:56 PM
